When i drive the car at 68-71 mph there is a vibration that you can feel all over the car and the rear view mirror will even shake, and there is a slight low pitch noise. The vibration is not there at other speeds. It became noticeable after I got new tires about a month ago. A week ago there was a stronger vibration when I was accelerating at 30 and 40 mph, I took it in and they said the u-joints were worn out and the replaced them which stopped the large vibrations. The car pulls to the right but barely. The check engine light is on and has come on and gone off for about 4 months. THe error message reads P0171 sytem too lean bank 1. the O2 sensor was replaced but it did not fix the error code message. I have had the tires rotated and balanced since I have had the problem.
2000 Toyota 4Runner Vibration
Have the tire company recheck the balance of the wheels.
The pull can be various things. Low tire pressure, a bad tire (regardless of age), alignment, suspension issues....Swapping the front tires from side to side will make the pull move to the other direction if it is the tire.
IF the diagnosis on the CEL turned up as the O2 sensor, it is possible that it may be a bad O2 sensor....At least have them check that first, there are many possible causes.
Suggested Repair
Have the tire shop recheck wheel balance. For the slight right pull, check tire pressure, a bad tire, alignment, and suspension; swapping the front tires side to side can show whether a tire is the cause. For code P0171, recheck the oxygen sensor first, since many other causes are also possible.
Conversation Summary
A 2000 Toyota 4Runner with 120,000 miles vibrates at 68-71 mph, with mirror shake and a slight low-pitch noise, after new tires were installed. Stronger acceleration vibration was resolved by replacing worn U-joints. The vehicle also pulls slightly right, and a recurring P0171 lean code remained after an oxygen sensor replacement. The expert recommends rechecking wheel balance, investigating tire, alignment, and suspension causes of the pull, and rechecking the oxygen sensor and other possible lean-code causes.
