1997 Toyota 4Runner Oil Seal Leak
URAYUTAY
Hello i have 1997 toyota 4runner LTD 117.000 milleage..mechanic said i have oil seal leak in the back of my right tire...i wanted to fix it myself cuz they are asking a lot of money...do you have the diagram for this?
May 3, 2006 at 4:49 AM
LOSONE
  • 1,616 POSTS
The procedure is a bit much for a novice mechanic because it involves removing the axle. Better let a pro do it because it might end up costing you more than you want to pay. Good luck
May 3, 2006 at 10:08 AM
Suggested Repair
Have a professional replace the rear axle oil seal. The repair requires axle removal and is not recommended as a novice DIY job.
Conversation Summary
The owner of a 1997 Toyota 4Runner with 117,000 miles was told there is an oil seal leak behind the right rear tire and asked for a diagram to repair it. The expert said the job requires axle removal and advised having a professional do it to avoid higher costs from a failed DIY attempt.
