Toyota 4Runner Knocking Noise
GUITARPUNK105
  • 6 POSTS
After pulling my tractor out of a rut in 2 wheel drive, my 4runner started to make a knocking noise that gets faster when the rpms go up. it makes no noise when it idles, but it does for a few seconds when you start it for the first time. it has a 3.0 litre V6 with 258000 Kms
Feb 27, 2007 at 4:45 PM
LOSONE
  • 1,616 POSTS
Sorry to say but it sounds like you might have spun a rod bearing or burned a main bearing. How is the oil presuure at idle and running?
That mileage the engine is almost at the end of it;s like. they had a lot of problems with head gaskets and there is a recall for it VO6.
I don't think it is a gasket problem. It probably needs a new engine.
Good luck losone
Mar 3, 2007 at 4:20 AM
Suggested Repair
Check oil pressure at idle and while running. The RPM-related knock is consistent with a spun rod bearing or burned main bearing, not a head gasket. At this mileage the engine may need replacement.
Conversation Summary
A Toyota 4Runner with a 3.0L V6 and about 258,000 km developed a knocking noise after pulling a tractor out of a rut in two-wheel drive. The knock speeds up with RPM, is absent at idle, and occurs briefly on the first start. The expert suspected a spun rod bearing or burned main bearing, asked about oil pressure, noted known head-gasket issues and a related recall but did not think that was the cause, and said the engine likely needs replacement.
