1997 Toyota 4Runner knocking in motor
FATTAPIG
  • 1997 TOYOTA 4RUNNER
  • 6 CYL
  • 4WD
  • 177,000 MILES
I have a bad knocking in the back of my motor. I just had the oil changed the day before it started. When you first start it up when its cold the motor does not knock for about 5 minutes. Can anyone please tell me what to do. Thanks Danny
Wednesday, February 20th, 2008 AT 11:44 PM
Knocking noises is it a clicking/tapping/rapping/thudding/thumping noise-
Might want to check the oil pressure for a start. Could be a clogged pick up screen/sludge/weak oil pump/engine bearings etc.
Thursday, February 21st, 2008 AT 12:05 AM
FATTAPIG
Its more like a thudding, its bad enough that I am afraid to drive it. Should I try a motor flush? Thanks Danny
Thursday, February 21st, 2008 AT 9:53 AM
You can try engine flush-don't work check the oil pressure. The knocking sounds like rod bearings
Thursday, February 21st, 2008 AT 1:43 PM
FATTAPIG
I am going to check the oil pressure, Would it be rod bearings if it runs good for about 5 minutes at cold startup? Thanks again
Thursday, February 21st, 2008 AT 1:57 PM
Could be who knows-knocking in the lower portion of the engine can be the rod or main bearings -check the oil pressure.
Thursday, February 21st, 2008 AT 2:19 PM
