1994 Toyota 4Runner Rear Window Won't Open
JOHN KASLIK
I have a 1994 toyota 4runner 88,000 miles, I have a problem with opening the reae window/door. When I try to open rear window with the key or button in cab I hear a small click and nothing happens I have never had any problem with the door before and I am sure that the electric motor hasnt burnt out Can you sujest anything Thank you john
Jul 21, 2007 at 9:23 AM
  • 75,988 POSTS
[quote:261853e64c="john kaslik"]I have a 1994 toyota 4runner 88,000 miles, I have a problem with opening the reae window/door. When I try to open rear window with the key or button in cab I hear a small click and nothing happens I have never had any problem with the door before and I am sure that the electric motor hasnt burnt out Can you sujest anything Thank you john[/quote:261853e64c]
Could be the rear power window control relay
Jul 21, 2007 at 9:29 AM
JOHN KASLIK
[quote:d4f4d3ae57="rasmataz"][quote:d4f4d3ae57="john kaslik"]I have a 1994 toyota 4runner 88,000 miles, I have a problem with opening the reae window/door. When I try to open rear window with the key or button in cab I hear a small click and nothing happens I have never had any problem with the door before and I am sure that the electric motor hasnt burnt out Can you sujest anything Thank you john[/quote:d4f4d3ae57]
Could be the rear power window control relay[/quote:d4f4d3ae57]
thanks for advice could you tell me how to identify the rear power window relay and where is it situated
thanks john I have checked the cable going to the motor and there is no power.Forgive me for being so stupid but I cannot still locate the PWCR could you explain in simple terms Also someone has sugested it could be the regulator regards john
Jul 22, 2007 at 7:27 AM
  • 75,988 POSTS
The PWCR is behind the left qtr. panel inner trim panel. Motor is left side of rear door.
Jul 22, 2007 at 8:35 AM
Suggested Repair
Check the rear power window control relay (PWCR), located behind the left quarter panel inner trim. The rear window motor is on the left side of the rear door. No power was found at the motor cable, so verify the relay and related wiring before replacing the motor or regulator.
Conversation Summary
A 1994 Toyota 4Runner with 88,000 miles clicks but does not open the rear window from the key or cab switch. The owner confirmed no power at the motor cable and asked how to find the rear power window control relay. The expert said the relay is behind the left quarter panel inner trim and that the motor is on the left side of the rear door. A regulator was also mentioned as a possible cause.
