2004 Toyota 4Runner Cargo door will not open
SML1972
  • 2004 TOYOTA 4RUNNER
Electrical problem
2004 Toyota 4Runner 6 cyl Four Wheel Drive Automatic
My 2004 4Runner cargo door wont open. I can hear the solenoid activates but the door wont open. The window opens and shuts and I havent got anything into the assembly.
Monday, May 25th, 2009 AT 11:58 AM
T4R DRIVER
I have similar symtoms on my 1998 4Runner.
I found my problem to be mechanical. The workaround:
Press inward FIRMLY on the bottom of the licence plate holder (i.E. Vertically the space between the cargo handle and where the cargo door latch actually is) with your left palm while engaging the handle with your right hand.
This engages the latch and opens the door. Oddly enough, it works for me. Maybe it'll work for you.
Monday, May 25th, 2009 AT 5:11 PM
SML1972
Thank you very much for the info and YES it worked. Will have to do till I can get it repaired. Is this a common issue with this SUV? Thank you very much, Scott
Thursday, May 28th, 2009 AT 4:50 PM
JMAXWELL
I have a 1997 4Runner and my cargo door was also giving me trouble. The solution offered (pressing in on it while opening) is exactly what I did for over a year until that stopped working. Then I replaced the latch mechanism with a OEM part that cost about $150 form a Toyota dealer. It works fine now. I wish I had replaced it sooner!
Thursday, June 4th, 2009 AT 10:43 PM
