1989 Toyota 4Runner No Start After Timing Chain Fix
JANEY44
after we change the timming chain the truck wont start and i wondering why it wont start . 1989 r22E 4x4 4 runner
Mar 23, 2006 at 5:08 PM
JANEY44
[quote="JANEY44"]after we change the timming chain the truck wont start and i wondering why it wont start . 1989 r22E 4x4 4 runner[/quote]
Mar 23, 2006 at 5:12 PM
JANEY44
it wont start up after the timming chain was replaced
89 r22e toy 4x4 4 runner
Mar 23, 2006 at 5:19 PM
  • 75,988 POSTS
Did you put engine on TDC before you remove the chain. If not you need to do that and then line up the sprockets Cam and Crank, makes sure rotor is pointing to no.1 on the distributor cap tower.
Mar 25, 2006 at 6:03 PM
Suggested Repair
Set the engine to top dead center if it was not set before the timing chain was removed. Align the camshaft and crankshaft sprockets, and confirm the distributor rotor points to the No. 1 tower on the distributor cap.
Conversation Summary
The owner of a 1989 Toyota 4Runner 4x4 with a 22R-E engine says the truck will not start after the timing chain was replaced. The expert asks whether the engine was set to TDC before chain removal and advises aligning the cam and crank sprockets and verifying the distributor rotor points to the No. 1 cap tower.
