1991 Toyota 4Runner Acceleration Issue
LALIE43
I have a 1991 Toyota 4Runner, stick shift, 4WD, with approx. 177,000 miles on it. I recently had the clutch replaced. Since then, I have had a difficult time accelerating whenever I shift gears, especially when going from 1st to 2nd. I was wondering two things: 1) In general, what could be causing this problem?; and 2) Is it possible that something during the clutch replacement process may have contributed to the problem?
May 27, 2007 at 4:40 AM
  • 75,988 POSTS
[quote:bc03e0a387="lalie43"]I have a 1991 Toyota 4Runner, stick shift, 4WD, with approx. 177,000 miles on it. I recently had the clutch replaced. Since then, I have had a difficult time accelerating whenever I shift gears, especially when going from 1st to 2nd. I was wondering two things: 1) In general, what could be causing this problem?; and 2) Is it possible that something during the clutch replacement process may have contributed to the problem?[/quote:bc03e0a387]
If the entire clutch assy was replaced new-could be further adjustment needed or a problem with the clutch master cylinder or the slave/servo.
Hope this helps.
May 27, 2007 at 9:01 AM
Suggested Repair
If the clutch assembly was replaced new, check for needed clutch adjustment and inspect the clutch master cylinder and slave/servo for problems.
Conversation Summary
The owner of a 1991 Toyota 4Runner with a manual transmission and about 177,000 miles reports difficulty accelerating when shifting, especially from 1st to 2nd, after a recent clutch replacement. The expert says a new clutch assembly may need further adjustment, or the clutch master cylinder or slave/servo may be at fault.
