1990 Toyota 4Runner Heater and A/C No Power
JAYS86MR2
  • 6 POSTS
i have a 1990 Toyota 4Runner. My heater and A/c doesn't turn on. i check the fuse and everything seems to be fine. i went to Kragens to ask if their are any parts for my heater to turn back on he said he didnt have anything and he thinks it might be a senser. whats a sensor. if anyone can help me out it would be great thanks
Nov 8, 2006 at 2:47 PM
BACKYARDMECHANIC
  • 337 POSTS
Dear Jay,
You say the heater and a/c doesn't work I'am assuming the fan motor is what you mean. Recheck the fuse for the fan motor and make sure it is good. If it is good check that power is getting to the fan motor with a volt meter or 12volt test lamp. If the fuse is good and you still have on power you need to check the fusible link. ( This is different from a fuse but works in a similar manner). I not sure where your model has it but here are two places to check. Sometimes it can be located under the hood in a box. Similar to a fuse box and it will be maked. The other location is right off the postive terminal of the battery. This will look like a bunch of wires ( like a wiring harness) and will be a little harder to tell which one is blown. If it is blown the link will feel soft in the location that it is blown and may be discolored. If the link is blown you probably have a short and will need to address that first before replacing it or you may just need to replace it again.
Nov 10, 2006 at 1:39 AM
Suggested Repair
Recheck the blower fan fuse, then verify power at the fan motor with a voltmeter or 12-volt test lamp. If the fuse is good but there is no power, inspect the fusible link under the hood or at the battery positive terminal. If the link is blown, find and repair the short before replacing it.
Conversation Summary
The owner of a 1990 Toyota 4Runner said the heater and A/C would not turn on. The fuse appeared fine, and a parts store suggested a sensor. The expert assumed the blower fan was not running and advised rechecking the fan fuse, confirming power at the motor, and inspecting the fusible link, which may indicate a short if blown.
