1993 Toyota 4Runner Heater Medium Speed
JEKRUG
  • 6 POSTS
I have a '93 4Runner 4WD, V6, with 159000 miles. All of a sudden the medium position of the heater motor switch stopped working. Is this repairable? Could this be fuse related? How do I remove the switch panel from the dash to repair/replace the switch?
Jul 31, 2007 at 1:52 AM
  • 75,988 POSTS
[quote:eff3aa1021="jekrug"]I have a '93 4Runner 4WD, V6, with 159000 miles. All of a sudden the medium position of the heater motor switch stopped working. Is this repairable? Could this be fuse related? How do I remove the switch panel from the dash to repair/replace the switch?[/quote:eff3aa1021]
Try checking the blower resistor at left side of blower housing if not it check the control switch.
Jul 31, 2007 at 10:16 AM
HUDSONHORNET
  • 6 POSTS
[quote="rasmataz"][quote:80a41db29f="jekrug"]I have a '93 4Runner 4WD, V6, with 159000 miles. All of a sudden the medium position of the heater motor switch stopped working. Is this repairable? Could this be fuse related? How do I remove the switch panel from the dash to repair/replace the switch?[/quote:80a41db29f]
Ok i had this Exact problem with my 93' 4runner. First i went to a junk yar, found a 4runner, pulled out the blower switch control thing. Payed 5 bucks for it. This is good, because:
1. gives you a chance to take apart the dash and pull out the piece without risking your vehicle.
2. the piece from a toyota dealer ship is $57. ( i checked)
The hardest part of removing the switch from the dash is that you need to remove the dash board(couple of screws) then the radio (couple of bolts and wires) and then all the tabs on the switches, then pull off the faceplate over the switches.
Now from this point its kinda just guess work, atleast for me, just remember that plastic bends a decent amount. Be carefull not to break the little light above the switches, and double check to make sure that it still works before you put your dash together again. I forgot to plug it in, and its not worth my time to take apart my car again.
But other then the light, the new switch works and i have heat and A/C again
Aug 1, 2007 at 10:35 AM
HUDSONHORNET
  • 6 POSTS
and by junk yard, i mean a car junk yard....
Aug 5, 2007 at 7:40 PM
Suggested Repair
Check the blower resistor on the left side of the blower housing, then the heater control switch. A failed medium speed is more often the resistor or switch than a fuse. The switch can be replaced after removing the dash screws, radio, switch tabs, and faceplate; confirm the switch and indicator light work before reassembly.
Conversation Summary
A 1993 Toyota 4Runner lost medium heater-fan speed. The expert advised checking the blower resistor beside the blower housing and, if needed, the control switch. Another owner with the same issue replaced the blower switch from a salvage vehicle after removing the dash, radio, and switch faceplate, and reported that heat and A/C speeds worked again.
