2002 Toyota 4Runner Engine won't turn over
2002 TOYOTA 4RUNNER
LSPAHN
Engine Mechanical problem
2002 Toyota 4Runner 6 cyl Four Wheel Drive Automatic
When I try to start the car, I get a clicking sound when the key is turned. Engine does not turn over. Battery is 16 months old. Is this a problem with the starter?
Feb 13, 2010 at 11:41 PM
No crank at all/nothing/nada:
Could be the starter, starter relay, clutch switch/park and neutral switch and ignition switch assuming the battery and connections are good.
Feb 14, 2010 at 6:33 PM
