1997 Toyota 4Runner
MMHARDER
  • 1997 TOYOTA 4RUNNER
1997 Toyota 4Runner V6 Four Wheel Drive Automatic 90000 miles
No heat, has replaced thermostat, radiator and flushed system. Filled system back up let run to temperature. Very little heat. Top hose hot and both heater hoses are hot and lower radiator hose and thermostat housing cold. Any other ideas on what we can do? Thanks Mark Engine not over heating could it possibly be the water pump.
Wednesday, December 5th, 2007 AT 7:34 PM
2CARPRO JACK
  • 11,533 POSTS
Is there a heater control valve inline on one of the heater hoses? If so, be sure it is working, if not could be a blend door problem under the dash. Look for what door operates when hot/cold is selected and be sure it is moving all the way. Get back with what you find
Friday, December 7th, 2007 AT 11:26 AM
