1996 Toyota 4Runner NO HEAT FRONT VENTS BUT OK AT BACK SEAT
TYME58DJ
  • 1996 TOYOTA 4RUNNER
  • 6 CYL
  • 4WD
  • 199,459 MILES
HEADGASKET-RADIATOR-HOSES -THERMOSTAT ALL REPLACED LAST YEAR. MAJOR RUST BUILD UP PRIOR TO HEADGASKET GOING UP. THE MECHANIC HAS BACKFLUSHED 8 TIMES ALREADY AND IT WORKS OK A FEW DAYS THEN STARTS AGAIN. NO HEAT ON ANY SETTING FRONT. BUT CAN FEEL HEAT IN BACK SEAT AREA DUCT EXIT. I WANT TO CHANGE HEATER CORE BUT MECHANIC SAID IT CANT BE THAT. BUT SO FAR CANNOT STOP THE PROBVLEM
Wednesday, December 19th, 2007 AT 10:58 PM
2CARPRO JACK
  • 11,533 POSTS
Is there a seperate heater control valve for just the front heater? If so I would wager that it is the restriction that is keep in it from happening. Be sure it works properly and check the hoses for the front to see if they get hot
Thursday, December 20th, 2007 AT 11:55 AM
