1994 Toyota 4Runner No Check Engine Light and No Start
LMONDRY
  • 1994 TOYOTA 4RUNNER
  • 6 CYL
  • 4WD
  • 186,000 MILES
The check engine does not come on at all, even with the ignition switch in the on position. Also have a no start/no spark problem. Can you help please?
Monday, October 20th, 2008 AT 12:43 PM
RACEFAN966
  • 5,029 POSTS
Have you pulled the distributor cap to make sure the distributor it turning as you crank it? It could be a broken timing belt. Let me know what you find.
Monday, October 20th, 2008 AT 5:34 PM
LMONDRY
Yes I did check the distr and mad sure all wires are pluged in. I also to ohm readings on the coil, pickup coil and all was in specs. The one thing that is stumping me is the check engine light does not come on with the key in the on position. There is power to the ecm and all fuses that control the ecm and efi.
Wednesday, October 22nd, 2008 AT 8:11 PM
RACEFAN966
  • 5,029 POSTS
Once again did you pull the distributor cap off and crank it to see if it turns?
Wednesday, October 22nd, 2008 AT 9:05 PM
