1994 Toyota 4Runner
SHANNON GALIETO
  • 1994 TOYOTA 4RUNNER
  • 6 CYL
  • 4WD
  • 205,512 MILES
We just put a new motor in my 4runner at about 200,000 miles, and alot of new parts in it but at about 5,000 miles the idle on the motor started acting up. We check the mass airsensor, the distributor, did a compression check on the motor, changed a few fuel injectors, put new spark plugs. The check engine light came on and code comes up as 26 stating that the motor is running rich.
Friday, June 4th, 2010 AT 5:30 PM
Probable causes of an engine running rich are as follows:
1. Fuel pressure not within specs. Can be cause by restricted fuel return line or defective fuel pressure regulator.
2. Defective Oxygen Sensors.
3. Leaking injectors.
4. Coolant temperature sensor out of calibration.
5. Restricted air intake system.
Friday, June 4th, 2010 AT 5:34 PM
