1994 Toyota 4Runner Intermittent no start
DLIV99
  • 1994 TOYOTA 4RUNNER
Engine Mechanical problem
1994 Toyota 4Runner 6 cyl Four Wheel Drive Automatic
My 4 Runner sometimes won't crank. I had the starter replaced and was told that would fix the problem, but it didn't. What else could be causing this and how can I troubleshoot it myself.
Thanks, dliv
Wednesday, April 30th, 2008 AT 7:18 PM
ROB2008
  • 258 POSTS
Heres a diagram of the starting system .Check your ignition switch , starter relay and the park /neutral position switch
https://www.2carpros.com/forum/automotive_pictures/181498_0900823d801604f7_1.jpg
Wednesday, April 30th, 2008 AT 8:33 PM
PULLENCABLE
I had a similar problem I turned out to be the wire from the ignition to the starter a hole had wore through the wire and grounded out onthe firewall.
The is after driving on hot days the starter wont crank maybe thermal protection
Saturday, May 24th, 2008 AT 10:31 AM
