Engine idles fine and takes throttle smooth as long as its not in gear. I can rev it all the way up and it doesn't skip a beat. In first gear I don't notice much, but second gear starts to lurch/misfire at about 2500 RPM and its noticeable in all gears on up. The problem is highly sporadic as well. Sometimes it comes and goes daily and sometimes its a problem for a couple days and then runs great for a week or more. And of course everytime I've taken it to my mechanic its run perfectly...
And a quick side question: on my 4Runner, do I have to drop out the gas tank to replace the fuel pump?? And if I have to is there any reason to not cut a hole in the floor of the truck and make an access panel instead of dropping the tank out?
Thanks!!
Thanks!!
Nov 28, 2008 at 8:25 AM
