Changed the plugs, wires, distributor cap, rotor, cleaned the intake manifold with new gasket. Throttle position sensor, air flow meter and harmonic balancer. Engine performance no better than before the above repairs made. Repair shop then suggested the fuel pump needed to be replaced.
The engine runs fine in neutral revs up with no missing or bogging down. Bogs down under acceleration in gear only.
SPONSORED LINKS
Saturday, January 3rd, 2009 AT 1:10 PM
