1994 Toyota 4Runner
BEBAUGH1980
  • 1994 TOYOTA 4RUNNER
  • 6 CYL
  • 4WD
  • 184,000 MILES
My 1994 Toyota 4Runner has no power I hear that all of these models with a v6 have the same problem how can I give it more power, it has no get up and go and takes forever to get up to speed.
Monday, May 12th, 2008 AT 12:09 AM
When was the last time it seen a major tune-up? Lost of power could be a problem with engine compression/weak or ou ttime ignition or fuel pressure problem and exhaust restriction- etc
Monday, May 12th, 2008 AT 4:17 AM
BEBAUGH1980
I recently bought this truck and I changed plugs and plug wires what else would you suggest?
Tuesday, May 13th, 2008 AT 12:43 AM
Spark plugs and wires is just 1/4 of a tune-up. I suggest you check compression and comeback with the readings and we'll go from there.
Tuesday, May 13th, 2008 AT 4:51 AM
