HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
4Runner
Engine
Symptoms
Low Power
SPONSORED LINKS
1990 Toyota 4Runner no power
SCORPION9220
MEMBER
1990 TOYOTA 4RUNNER
4 CYL
4WD
MANUAL
18,000 MILES
I have a 22r motor with a 5 speed transmission on hills it has no power is there anything I can do to get morw power
Wednesday, June 10th, 2009 AT 8:01 PM
MECHANIC
Check the exhaust system for restriction could be the catalytic converter be causing it-
SPONSORED LINKS
Thursday, June 11th, 2009 AT 4:53 PM
SCORPION9220
MEMBER
Just put a new catalic converter on last week
Saturday, June 13th, 2009 AT 9:40 AM
MECHANIC
Do you have a check engine light and when was the last tune-up?
Saturday, June 13th, 2009 AT 2:38 PM
Please
login
or
register
to post a reply.
Related Engine Low Power Content
1990 Toyota 4runner Lack Of Top End Acceleration
When I Purchased This Used Vehicle It Drove Fine In Town. I Then Found That Out On The Highway I Had To Run Full Throttle To Eventually...
Asked by
lazyds
1 ANSWER
1990
TOYOTA 4RUNNER
VIDEO
Fix an Engine with Low Power!
Instructional repair video
GUIDE
Symptoms of Low Engine Power
The power your car's engine is producing is important. When you step on the gas you need your car to accelerate, mainly to keep you out of trouble when getting onto the...
Engine Loses Power Intermittently.
Hi, I Have A 1994 Toyota 4runner V6 Sr5. I Have A Problem With The Engine Losing Power Intermittently. The Motor Loses Power And And If I...
Asked by
Aykoss
1994
TOYOTA 4RUNNER
1998 Toyota 4runner Overheating And Loss Of Power
I Work In Zimbabwe With The U.S. Embassy So Good Car Maintenance Is Difficult. Several Months Ago, My Car Started Overheating When I Would...
Asked by
Glenn Warren
1998
TOYOTA 4RUNNER
1994 Toyota 4runner Engine Bogs Down In Acceleration...
Changed The Plugs, Wires, Distributor Cap, Rotor, Cleaned The Intake Manifold With New Gasket. Throttle Position Sensor, Air Flow...
Asked by
creolekennels
1 ANSWER
1994
TOYOTA 4RUNNER
2000 Runner Sr5- Bogging Down
2000 Toyota 4runner Sr5 4wd, V-6, 140k Miles- When It Starts Out, Up Until About 2000 Rpm, It Really Bogs Down Almost To The Point Of...
Asked by
borgs8
2000
TOYOTA 4RUNNER
VIEW MORE
SPONSORED LINKS
Catalytic Converter Test
Online car repair manuals
