Engine Torques specification
569,325 MILES • 2.0L • 4 CYL • 2WD • MANUAL
LUCKY BALOYI
I am doing an engine overhaul on the vehicle and I am replacing with new pistons, big end and main bearings replacement. I need assistance on the torque specification for big end bearings, main bearings and cylinder head. And I have noticed that the coolant/water pump pulley is not in the center of the pump, which clear means it has to be fitted at a certain position and I am not so familiar with these engines. Please assist.
Regards: Lucky
Oct 10, 2018 at 11:23 PM
  • 55,562 POSTS
Here are the engine torque specs and a video on how to use a torque wrench correctly (just in case you need it):
https://youtu.be/juOClONIWeY
Cheers, Ken
Oct 12, 2018 at 3:46 AM
LUCKY BALOYI
Hi there Ken, Thank you for the prompt reply. I have completed the repairs on the engine according to specs and the motor is fitted back on the vehicle, its running smooth.
Regards: Lucky
Oct 22, 2018 at 5:00 PM
  • 55,562 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Cheers, Ken
Oct 23, 2018 at 3:25 AM
