2001 Pontiac Grand Am Intake Manifold Torque Specs
210,000 MILES • 3.4L • V6 • 2WD • AUTOMATIC
NORMANBUTLER56
I need the torque specs for the intake manifold on my car listed above.
Mar 25, 2018 at 5:55 AM
Good afternoon.
Attached is the sequence for tightening the bolts and specs.
Install new lower intake manifold bolts.
The torque specification is a two step process; tighten the vertical lower intake manifold bolts (the four middle ones) to 7 Nm (62 lb in). Tighten the diagonal lower intake manifold bolts (two on each end) to 7 Nm (62 lb in). Tighten the vertical lower intake manifold bolts (the four middle ones) to 13 Nm (115 lb in). Tighten the diagonal lower intake manifold bolts (two on each end) to 25 Nm (18 lb ft).
Upper intake manifold.
Tighten bolt/stud, 25 Nm (18 ft. lbs).
Mar 25, 2018 at 7:02 AM
Suggested Repair
Install new lower intake manifold bolts and tighten in the specified sequence: first all lower bolts to 7 Nm (62 lb in), then the four middle vertical bolts to 13 Nm (115 lb in) and the diagonal end bolts to 25 Nm (18 lb ft). Tighten the upper intake manifold bolt/stud to 25 Nm (18 ft lbs).
Conversation Summary
The owner of a 2001 Pontiac Grand Am asked for intake manifold torque specs. The expert provided a two-step lower manifold sequence and the upper manifold torque: lower bolts first to 7 Nm (62 lb in), then middle vertical bolts to 13 Nm (115 lb in) and diagonal end bolts to 25 Nm (18 lb ft), with the upper bolt/stud at 25 Nm (18 ft lbs).
