1997 Pontiac Grand Am Intake Sludge
NAVYBUDD
97 Grand am 3100 v6 100,000 miles. I just removed the manifold to replace the manifold gasket and the inside is coated with a not rediculouse but descent amount of sludge. What is the best way to clean this out and does this result from a lubricant that needs to be there. Should i go crazy with the carb cleaner and clean it dry? I have no idea what goes through here or how to prepare it to build back up.
Jul 23, 2007 at 3:34 PM
  • 75,988 POSTS
[quote:6ce5dea617="navybudd"]97 Grand am 3100 v6 100,000 miles. I just removed the manifold to replace the manifold gasket and the inside is coated with a not rediculouse but descent amount of sludge. What is the best way to clean this out and does this result from a lubricant that needs to be there. Should i go crazy with the carb cleaner and clean it dry? I have no idea what goes through here or how to prepare it to build back up.[/quote:6ce5dea617]
Please! do so,go crazy with the carb cleaner and clean it dry then go find/change your PCV valve
Jul 23, 2007 at 3:57 PM
CLY
  • 308 POSTS
One thing to keep in mind is that you want to keep as much as possable from going down into the motor.That stuff will plug the oil pick-up tube in the oil pan....After you are done you will want to change the oil and on the next couple of oil changes you may want to add some engine flush before changing to try and get whats left out...
Cly
Jul 23, 2007 at 9:09 PM
Suggested Repair
Clean the intake manifold thoroughly with carburetor cleaner and dry it, keeping sludge from entering the engine. Replace the PCV valve, change the oil afterward, and use engine flush on the next couple of oil changes to remove remaining sludge.
Conversation Summary
The owner of a 1997 Pontiac Grand Am 3.1L found a moderate amount of sludge inside the intake manifold while replacing the gasket and asked how to clean it. Experts advised cleaning it dry with carburetor cleaner, replacing the PCV valve, preventing debris from entering the engine where it could clog the oil pickup, then changing the oil and using engine flush on subsequent changes.
