Too much transmission fluid
2005 JEEP LIBERTY
168,500 MILES • 3.7L • V6 • 4WD • AUTOMATIC
CASMIHOK
  • 205 POSTS
So, I been having some issues with my truck. I finally got this crankshaft sensor out after pb blasting it for two weeks and working it loose. I replaced it with a new one. Took it for a ride last night, felt pretty good except some hesitation/grinding around 2000 rpm.
I just noticed that there's excess transmission fluid. My dipstick read beyond the hot line, when the engine was cold. Just trying to gauge how bad this situation is? I didn't put much mileage on it with this excess fluid. Maybe an hour or two, because I had went to Valvoline for an oil change about a two months ago and they "topped off" my transmission fluid. Which now, either I see they added way too much or it didn't need it.
So, I'm going to drain some from the bottom. In the liberty, I'm pretty sure there's no drain plug just loosen the nuts and let's some seep out?
As far as damage to the transmission, should I be stressing? Thank you
Jan 7, 2020 at 7:28 PM
  • 110,194 POSTS
I wouldn't worry at this point, but it should be taken care of. I would return to the shop the did the work. Often times, they will have a pump which can draw the fluid through the dip stick tube. If you loosen the transmission pan, there is a good chance the gasket (if there is one) or sealant will leak when you it's re-tightened.
Let me know if I can help in any way. Also, take it back. Remember, ATF expands when it gets hot, so if it is at the full hot mark when cold, it's certainly over full.
Jan 7, 2020 at 9:13 PM
CASMIHOK
  • 205 POSTS
Hi Joe,
So minor dilemma now, I lost the bolts to try and get some out. No dice.
So re-tightened them, however I stripped two bolt holes. I was very careful and they barely even got tight before stripping. All the other ones were totally fine.
So now what? Am I bummed? If the bolt holes are stripped, I'm sure that's quite a task to deal with. At that point I'd have to take the pan completely off and replace the female threads?
I'm supposed to go get my new tires mounted at 9 am tomorrow, it's only a mile down the street. Bad idea to drive with three missing bolts on the transmission pan? They aren't next to each other, still don't know if I should call and reschedule.
Thank you
Jan 7, 2020 at 9:39 PM
CASMIHOK
  • 205 POSTS
Joe, I'm seriously stressed if my transmission was damaged. Is damage typically not done that soon?
Jan 8, 2020 at 11:07 AM
  • 110,194 POSTS
As far as the stripped bolts, you really don't need to remove the entire pan. You will need to tap new threads into the transmission housing. Do you have a basic tap and die set?
As far as what happened, it isn't hard to do. The housing is aluminum with steel bolts going into it. They are easy to strip. You aren't the first and won't be the last. LOL You have no idea how many times they corrode and break on the way out.
As far as the missing bolts, if there is no leak and the others are tight, you should be okay. Just pay attention if it starts leaking. If it does, it won't be an all at once issue. It may start to seep.
Finally, I really feel you will be fine with the transmission. Although you really don't want it overfilled, for a short time, you will be okay. I do have a question for you. When you checked the fluid level, did you check it with the engine running and the transmission in neutral? I ask because if you checked it with the engine off, it can appear over full. Once started, the level will drop. It should be checked with the engine at operating temp and the engine running (idle) and the transmission in neutral. Double check the neutral idea. It will say on the dipstick if it should be in park or neutral, but on many trucks manufactured by Chrysler, it is neutral.
Try to relax. It really isn't as bad as it seems. I can help you get through it. Let me know the answers to the questions I asked so I can properly direct you. I'm here to help the best I can.
Jan 8, 2020 at 6:32 PM
CASMIHOK
  • 205 POSTS
I appreciate it thank you. I just got new tires mounted, they said two bolts female threads are stripped and the third is basically about to be stripped so they didn't want to force it in.
I checked it with the car cold and off, but then I checked it while it was running today and it was good. However, it was in park, so next time Ill do it in neutral. Thank you for that advice
I do not have a tap and die set, I did see some youtube videos. Im willing to do it if it isn't too difficult. I would probably need to borrow a jack, Im small but even with that advantage, it's incredibly taxing on back and elbows to be under there in that small awkward space.
I have a 13 hour (give or take) trip to make home to my Momma, when I get back to my home state I have a friend who can help me do it on a lift in his garage. My one friend said his only concern is that because those bolts are missing, and not providing upward force, he worries fluid will seep out the gasket on top.
Im going to have him let me borrow a torque wrench, and a jack. And Ill see if I can find a tap and die set. Is that all I need?
Thank you
Jan 9, 2020 at 9:06 AM
  • 110,194 POSTS
Yes, it is important to keep an eye out for a leak, It may begin to seep. Now, on a lot of these vehicles, in place of a gasket, a sealant was used. If that is what you have, it should stay stuck together. Please understand, I'm not there and am only telling you what I feel can happen. With that, please keep an eye out for a leak. A 13 hour trip is really extensive and since I now know that, I'm a bit concerned. You may want to have it done before you go. Most parts stores will lend / rent you the set or sell them to you at reasonable prices. And yes, all you need the tap and die set. However, remember, when you tap the housing, you are changing the size and possibly the thread pitch. So, take the tap you plan to use to a store and tell them you need bolts that will work after you tap the housing. On the tap itself the size and thread pitch should be indicated. Make sure to get the same length as well. One last thing, and sorry I'm being so wordy, when you do this, take your time and make sure the tap enters the housing straight. You don't want the hole to be on a slant.
Please let me know if you need help and how things work out for you.
Jan 9, 2020 at 6:47 PM
CASMIHOK
  • 205 POSTS
Yea I'm pretty sure a sealant was used. It's not looking like a gasket, looks like a silver goo kinda seeping over corners and such.
Yea, I'm going to get it fixed before I go, I just want to go home but not worth risking getting trapped somewhere halfway in a strange state. So, I'm still super confused about this process of tap and die.
https://www.amazon.com/dp/B07DWBRBVM/ref=cm_sw_r_other_apa_i_V5ogEbPVA8DW6
Would this provide the right size I need? Or are you not really sure?
Sorry I'm literally starting at zero knowledge in this case scenario.
Thank you sincerely, I really appreciate this website.
Jan 10, 2020 at 1:37 PM
  • 110,194 POSTS
Honestly, not being there makes it difficult for me. What I would suggest is this. Remove one of the good bolts and take it with you to an automotive parts store or a store that would sell tooling. Show them exactly what you have. Tell them you need to tap the housing to the next size. If they have the bolt in their hands, they should be able to determine exact size and pitch of the threads.
I found this site online. The people that did it did a nice job explaining. Take a look through it.
https://www.google.com/search?q=how+to+tap+a+bolt+hole&rlz=1C1SQJL_enUS862US862&oq=how+to+tap+a+bolt+hole&aqs=chrome..69i57j0l5.7306j0j7&sourceid=chrome&ie=UTF-8#kpvalbx=_SRAZXrnHLZGV5wLSpaiQBA30
Let me know if that helps.
Jan 10, 2020 at 4:02 PM
CASMIHOK
  • 205 POSTS
Could I possibly just take a bolt to my local Walmart and measure it in one of their bolt measuring things, and then just go a size up? Is there no resource online or manufacturer website that provides details such as ones this specific? I don't have a manual, didn't come with one. Let me know, thank you. My buddy let me borrow his jack and he said he has some tap and die stuff so right now just working on the size.
Jan 11, 2020 at 10:49 AM
  • 110,194 POSTS
Yes, you could do that. When you go to size it, just go to the next size up. Keep in mind, the original one is most likely metric, so I would go to what is the next size standard. Also, make sure you not only pay attention to the diameter but also thread pitch. Make sure the tap you use is the correct one for the bolt you purchase.
I wish I was there to help. It really isn't that hard, but if you never did it before, it's confusing.
Let me know if you need help.
Jan 11, 2020 at 8:53 PM
CASMIHOK
  • 205 POSTS
Yea, LOL I am getting that vibe. But, at least after this Ill have it under my belt for experience! Thank you, I will keep you posted. Enjoy your Sunday
Jan 12, 2020 at 11:57 AM
  • 110,194 POSTS
Let me know how things turn out. If you need anything, let me know.
Jan 12, 2020 at 7:44 PM
CASMIHOK
  • 205 POSTS
What's the next size in standard from an M8 1.25?
Jan 19, 2020 at 9:28 AM
  • 110,194 POSTS
It sounds like you are ready. Here is what I would be doing at this point:
Drill the old threads out with 5/16" drill bit so it is straight and clean. (basically you are cleaning the old threads from the opening) Then, use a 3/8-16 tap. Just make sure to stay straight. Then purchase a 3/8-16 bolt the same length as the original.
When you start tapping the threads, turn the tap in and out while doing it. In other words, one turn in, and a half out and continue that process until finished. That helps keep it clean internally when cutting. Next, and this is extremely important, do not force the tap. You do not want it to break in the housing. You will not be able to drill it out, so be careful. Make sure you use some form of lubricant. They make a cutting oil, but WD40 will work.
Please let me know if this helps, if you have questions, or need help in any way.
Take care of yourself.
Jan 19, 2020 at 7:52 PM
