Too much fuel pressure
180,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
BARRETT330
Getting too much fuel pressure with my truck. Have put in new fuel pump and damper. Starts and idles fine its only when I start to drive it that I am getting too much fuel pressure. Have not been able to perform a fuel pressure test. I have not done much mechanical work. I actually had a friend helping so far and hoping someone can tell me what the problem might be.
Aug 4, 2017 at 8:27 AM
CATAFINA
  • 98 POSTS
Check the fuel pressure regulator.
Aug 4, 2017 at 3:24 PM
CARADIODOC
  • 34,415 POSTS
What is the symptom that makes you think the fuel pressure is too high? How can you tell if you have not measured it?
Aug 6, 2017 at 6:57 PM
