Ignition Timing?
1997 NISSAN TRUCK
290 MILES
MATTHEW PEERY
Just replaced timing chain, crank shaft gear, an camshaft gear. I had everything aligned with there proper timing mark's. My question is where are the timing mark's located at on the timing cover? I cannot seem to locate them. please help. thank you so much
Sep 9, 2017 at 2:01 PM
STEVE W.
  • 15,344 POSTS
There are none on the four cylinder. There should be a small pin that sticks out of the cover and it points to marks on the balancer itself. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Sep 9, 2017 at 2:12 PM
