Timing marks
2005 DAIHATSU CHARADE
80,000 MILES • 1.0L • 3 CYL • 2WD • MANUAL
POWERMANDLA
I have done rings and bearings but the car does not have power.
Oct 11, 2018 at 3:41 AM
  • CAR REPAIR CONTRIBUTOR
  • 110,190 POSTS
If the engine is running, the timing must be okay. A lack of power can be the result of several things. Take a look through this link. It discusses may common causes why a vehicle may have low power.
https://www.2carpros.com/articles/engine-has-low-power-output
If nothing there is helpful, check engine compression. That can help diagnose timing issues, low compression. I realize you replaced rings, but that does not mean there is a problem with the valves or a head gasket issue (even though it is new).
I have to apologize in advance. This vehicle is not offered in the US, so I have no technical information specific to it. However, they all work the same, so check out the link and compression if needed.
Oct 11, 2018 at 6:10 PM
