We do not have the 1.2 in the states, but this is from a similar engine can you see if its the same? Diagrams below, if so I can get the rest for you showing how to set the timing. Check out the diagrams (below). Please let us know what you find.
Images (Click to make bigger)
Thursday, November 29th, 2018 AT 12:12 PM
A*J*S
MEMBER
1 POST
Thank you it worked by using the diagrams you gave.
Tuesday, January 1st, 2019 AT 2:11 PM
KEN L
MASTER CERTIFIED MECHANIC
Nice work, we are here to help, please use 2CarPros anytime.
Thursday, January 3rd, 2019 AT 11:19 AM
HEIN
MEMBER
1 POST
2005 VOLKSWAGEN POLO
15,000 MILES
I need to know where to align the cam timing mark on the car listed above it the 1400 model with an eight valve blm engine. I changed head gasket. I can see the mark on the pulley, but what does it align with? There is no backing plate only a plastic cover with no markings this is different to the Jetta or Golf that is why I need advice.
Saturday, August 29th, 2020 AT 12:35 PM
(Merged)
KEN L
The manual way is to remove the valve cover and look at number four cylinder. It has to be on valve overlap which means the intake and exhaust are open at the same time the exact amount of lift. You can use a level on the lobes to verify. You should be able to look at these diagrams so you can see where the marks are (below) Please let us know if you need anything else to get the problem fixed.
(Merged)
SEFAKO
MEMBER
1 POST
150,000 MILES
I need to setup timing of my car listed above with a 1.6L engine. I don't have timing marks.
(Merged)
KEN L
Here are the timing belt diagrams to align the camshaft timing. Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
(Merged)
ANESHSUKDEN
MEMBER
1 POST
2001 VOLKSWAGEN POLO
192,000 MILES
I am from South Africa and I have a 2001 VW Polo Playa 1.6. I think my engine timing has been set off. I am familiar with cars and would like to sort it out myself but I dont know where the timing marks must aling. Do you maybe have a timing sheet I could follow.
(Merged)
EXOVCDS
MECHANIC
Do you know the engine code? There are different versions of the 1.6L engine. I need to know which one you have, so that I can find the correct information.
(Please give us feedback in the the vote tool below)
Thomas
(Merged)
2CP-ARCHIVES
MEMBER
1998 VOLKSWAGEN POLO
95,000 MILES
What are the timing belt marks for a 1.6 petrol polo
(Merged)
EXOVCDS
MECHANIC
I have found this timing belt diagram (below) which should give you the information you need to get the job done. We don't have a Polo but these should work
