How do I reset the theft system?
131,000 MILES • 3.1L • V6 • 2WD • AUTOMATIC
REDNECK0819
  • 8 POSTS
It says: Starting disabled due to theft system.
Nov 1, 2020 at 5:55 AM
Here is a guide that will help with the common ways to disarm it:
https://www.2carpros.com/articles/how-to-reset-a-security-system
If this doesn't work then we will most likely need to scan for codes to see if there are any there and that will tell us what the issue is. Also, have you tried another key? If not, let's do these two things in addition to the guide above and go from there.
Nov 2, 2020 at 9:05 AM
  • 110,248 POSTS
There is no reset. However, try this. Turn the key to the run position and allow it to sit for approximately 10 minutes. The theft light should turn off and the car should start. Try that and let me know if it works.
If it does or doesn't, we need to retrieve diagnostic trouble codes to see where the problem is coming from. I don't know if you have the original key, if there is a problem with one of the components or what is happening at this point. You may end up having to scan the can bus system to see if anything shows up. Here is a video showing how that is done:
https://youtu.be/InIlnsjOVFA
Let me know and we'll figure it out together.
Nov 2, 2020 at 9:09 AM
