Water pump
110,000 MILES • 2.2L • TURBO • 2WD • MANUAL
AZOUZ TITOUCH
The water / cooling system is playing up. it is fine for a few journeys, but then gives a low water level warning. When the cap is taken off to replenish the water, lots of air pressure is released and the then the water level returns back to the proper level on its own.
Jul 16, 2016 at 6:46 PM
SATURNTECH9
  • 30,868 POSTS
Have you tried replacing the cap?
Jul 17, 2016 at 1:36 AM
AZOUZ TITOUCH
yes.
Jul 17, 2016 at 8:12 AM
SATURNTECH9
  • 30,868 POSTS
I have seen cars go a little lower then go back up, but not enough to run the low coolant light on. Are you sure it is up to the full line to start with?
Jul 17, 2016 at 8:26 AM
