compression test
1992 VOLKSWAGEN GOLF
200,000 MILES • 2.8L • VR6 • 2WD • MANUAL
LARKSMUFF
is there anyway i can do a compression test to know the engine actually works? The engine is not wired up.
Oct 26, 2017 at 10:32 AM
STEVE W.
  • 15,349 POSTS
Sure, just use a regular battery and jumper cables to jump the starter and crank it over for the test. Just prop it up so it is solid and the flywheel is clear. Pull all the plugs. Then connect the battery positive to the starter and connect the negative terminal at the battery end. Connect the other end to the block. Use a piece of wire or a remote switch to activate the starter.
Run both a dry and a wet test if the engine has not been run in a while as setting can cause issues.
Oct 26, 2017 at 11:03 AM
LARKSMUFF
thank you so much! I will give this a try and get back to you.
Oct 26, 2017 at 11:15 AM
  • 55,433 POSTS
Here is a guide hat can help as well:
Cheers, Ken
Oct 27, 2017 at 7:12 AM
