the car will not start
180,000 MILES • 0.8L • V6 • 2WD • AUTOMATIC
CRYSTAL MEADOWS
My problem started when I drove to a gas station to get something to drink. I left from home and drove about two miles to the gas station. When I got back in my car it started fine but I put it in reverse and it stalled. Started right back up and got drove to stop sign and as I pressed the gas to go and it felt like it had hiccups until about second gear that it ran fine till I parked it. turned it off and waited thirty seconds and started the car right back up. The next day it stalled after it was warm.Only when I put the car in drive or reverse. Than the hiccups in second going to third. Not a bucking. So I replaced the fuel pump. Fixed the problem for a day or two. Then back to the previous conditions. So I changed air filter, checked mass air flow sensor and it was good. changed EGR value, crankshaft sensor, camshaft sensor, PVC valve. Same problem continued. Charged spark plugs and wires.started it up to warm it up and it stalled after four minutes or so. would not start up after that. Changed ignition switch and key lock cylinder Either Née keys. Did the ten minute relearning process, security light went off. Tried to restart and still nothing. Will crank but not start. Also checked the coil packs and they are good. Need help! Where to go from here? No codes pop up. On four different scanners.
Jun 21, 2017 at 11:55 AM
HARRY P
  • 2,292 POSTS
What about the fuel filter? Have you changed it? A clogged fuel filter could cause the issues you are describing.
If that does not do it, get a spark tester and check the sparks. https://www.2carpros.com/articles/how-to-test-an-ignition-system.
Jul 30, 2020 at 9:57 AM
CRYSTAL MEADOWS
Yes, fuel filter was changed. it had spark when I last started it and it was running fine than it stalled. Have not been able to restart it. I will check to see if it has spark after work today.
CRYSTAL MEADOWS
No spark! Thinking it my be the harness to the camshaft senor! It has a bare wire showing and has a little oil in the top of the connector!
HARRY P
  • 2,292 POSTS
Definitely get that bare wire and harness issue figured out. Let us know
CRYSTAL MEADOWS
Fixed the harness! Still no start! replaced another camshaft senor and it fixed the problem! Most have bought a bad camshaft sensor!
HARRY P
  • 2,292 POSTS
Great! I'm glad we were able to get it figured out.
