The AC will not work
2009 SCION XB
214,000 MILES • 4 CYL • 2WD • MANUAL
FBIKORWA
The climate control lights are completely off. When you turn the AC on/off the light does not turn on, defroster the same will not light up.
When you turn the fan on it blows to all the speeds, five of them.
When you select the cold temperature you only get the heat. When you select the heat, it works perfectly fine.
Can you help fix the AC?
Aug 16, 2018 at 7:08 AM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
A few questions first. How long has it been since/if refrigerant added? Do you notice if the A/C compressor cycles when the system is turned on and engine running? Let us know and we will be happy to help. I have also attached a few links for you to view. Hope this helps. Thanks for using 2CarPros.
Danny-
https://www.2carpros.com/articles/air-conditioner-how-to-add-freon
https://www.2carpros.com/articles/air-conditioner-leak-detection
Aug 16, 2018 at 11:21 AM
FBIKORWA
Hi Danny -
This has been going on for couple of month (four plus month), I just parked the vehicle since I have another one I was using. But then I decided that I wanted to work on the issue and fix it myself if I can.
Yes, the A/C compress cycles when the system is turned on and the engine running.
Yesterday, I added some Freon, however before I could do that, I connected the gauge and when I checked the low pressure reading it was in red at 150psi.
I proceeded by reducing the pressure all the way to 0 psi, then added some Freon up to 45 psi.
Aug 17, 2018 at 10:44 AM
DANNY L
  • 5,648 POSTS
Hello again.
Have you checked the Heater-A/C control unit? I understand functions work. But are you adding the refrigerant correctly?
Danny-
Aug 17, 2018 at 8:03 PM
FBIKORWA
Hi Danny,
To be honest, I would be lying if I said that I am adding the refrigerant correctly. I attempted to follow the direction as best as I can but I cannot say with certain that I am doing everything 100% correctly.
Aug 21, 2018 at 2:59 PM
DANNY L
  • 5,648 POSTS
Hello again.
Well no harm in trying to do it yourself. The problem is A/C systems are quite touchy being over/under filled with refrigerant. All systems have a specific fill limit. Being both under and overcharged will result in poor performance. Best bet is to use a professional machine evacuate system-see if it holds a vacuum-and them fill to specific system capacity. Hope this helps and thanks again for using 2CarPros.
Danny-
Aug 22, 2018 at 1:53 PM
FBIKORWA
Thank you so much Danny.
I have looked for that vacuum machine and will give it a try and let you know.
Thank you for taking the time to read me.
Aug 22, 2018 at 2:02 PM
DANNY L
  • 5,648 POSTS
You are welcome!
Thanks again for using 2Carpros.
Danny-
Aug 22, 2018 at 4:07 PM
