Temperature gauge not working properly?
95,369 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
TKWITLOCKS
My temperature gauge goes up when I’m driving, but I turn the heat on and ride with it on and it goes down. I don’t give it a chance to run hot, but it gets pretty high.
Feb 25, 2023 at 6:28 AM
  • 110,248 POSTS
If the heater helps cool it, my first suspect is the coolant thermostat. It may not be fully opening. However, first check the coolant level to make sure it is full. Do this when the engine is cold.
If that isn't a concern, then I would replace the thermostat. Additionally, when it is apart for the thermostat, I would flush both the radiator and engine block.
Here is a link that explains in general how one is replaced:
Here is a link that explains how to drain and flush the cooling system:
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
Let me know if you are comfortable doing these things and if you have other questions.
Feb 25, 2023 at 3:27 PM
