Overheating
107,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
ENOS1801
Hello, I am wondering why my car is overheating a bit. it goes over the half way mark but never in the red. I changed out the water pump, thermostat, radiator and temperature sensor, but it still does this. what could it be?
Aug 15, 2019 at 3:17 AM
Good afternoon.
Does the cooling fan operate? It should come on at 217 degrees and go off at 195.
https://www.2carpros.com/articles/symptoms-of-an-overheating-engine
https://www.2carpros.com/articles/how-an-electric-cooling-fan-works
Aug 15, 2019 at 6:52 AM
ENOS1801
Yes, I replaced the fans as well forgot to add that. They both would come on but then again after the driver side fan wouldn't. I switched the connectors around and now they both come on together and cut off together.
Aug 15, 2019 at 7:25 AM
Okay, what temperature do they come on and go off?
Aug 15, 2019 at 7:27 AM
ENOS1801
I am not sure, how would I check that?
Aug 15, 2019 at 7:31 AM
You can get an infrared gun. Harbor Freight has them for about $15.00 to $20.00. Then you can take the temperature of the coolant at the thermostat housing and see the actual temperatures.
Aug 15, 2019 at 7:33 AM
ENOS1801
Okay I'll look into getting one maybe today. I'll get back to you and let you know. Thanks Roy!
Aug 15, 2019 at 7:40 AM
You are welcome.
Always glad to help.
Keep us updated.
Aug 15, 2019 at 7:42 AM
