This is a little tricky because there is no direct ground. There is a reference circuit (voltage supply) and then a signal return circuit. Which means the circuit starts and ends at the TCM. The TCM sends the power, the sensor just alters the voltage and sends it back to the TCM.
So the TCM actually grounds the circuit through the TCM ground but the TCM is in between the sensor and the actual ground. The way it knows what speed the input is going is by how fast the voltage is pulsing from around 1.5v up to 3.5v and back and forth with the teeth and gap of the tone wheel on the input shaft.
Does this make sense? Let me know what questions you have. I attached the wiring diagram for your review. Thanks
Images (Click to make bigger)
Saturday, December 12th, 2020 AT 3:37 PM
