won't shift out of park
CHEVROLET SILVERADO
JIM007
1997 Chevy Silverado 5.7L (350ci) auto. 186k
Truck will not not shift out of park after the engine is started. Brake lights work so I don't think it's the brake light switch. Ignition? Seat sensor? Thanks.
Sep 15, 2007 at 8:23 PM
  • CERTIFIED EXPERT
[quote:701e281e95="Jim007"]1997 Chevy Silverado 5.7L (350ci) auto. 186k
Truck will not not shift out of park after the engine is started. Brake lights work so I don't think it's the brake light switch. Ignition? Seat sensor? Thanks.[/quote:701e281e95]
Check assigned fuse-could be an interlock system lock switch at brake pedal bracket/shift lock solenoid/park switch or bad ground.
Sep 15, 2007 at 8:37 PM
