Tank vent open code
150,000 MILES
Can the tank vent open code stop the car from starting? Because every time the code comes the injectors cannot open and the car does not want to start. have checked every possible pipe leak, still nothing or can the throttle be the cause as well?
Oct 4, 2019 at 11:25 PM
More than likely this is a purge valve issue. It is not an external leak but what happens is the purge gets stuck open and sets the code. The reason it cannot start is when the purge is open it is allowing fuel vapor into the engine basically it is putting too much fuel in and it cannot fire the engine.
Unfortunately, we don't have a Polo in our service manuals so I cannot get you specific data on this one but if it were me, I would replace the purge and go from there.
Let me know if you have questions. Thanks
Oct 6, 2019 at 8:34 AM
