Tail light not working
130,000 MILES
FRANSBUBBLE
My left tail light is out how do I repair it?
Nov 26, 2017 at 7:49 AM
  • 110,248 POSTS
If it is just a bulb, you need to remove the light assembly. Open the trunk and behind the light assembly is a trim panel. Carefully pry the trim panel back so you can see where the assembly is mounted. Next, remove the 10mm nuts holding the assembly. Finally, the assembly has a clip holding the furthest section of it on the fender. Carefully wiggle the assembly to remove the clip. Note: The assembly is plastic and can break easily, so be careful.
Nov 27, 2017 at 7:02 AM
