SUV will shut off at any speed
2001 CHEVROLET TAHOE
230,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
TAHOE00001
SUV will shut off while driving. Shut it off for few minutes and will start back up then will shut back down. Changed the crankshaft position sensor and it still will not start. Put old crankshaft position sensor in and it starts right up.
Oct 21, 2019 at 7:37 PM
  • 110,240 POSTS
Welcome to 2CarPros.
I feel you are on the right track with the sensor. Although a new sensor did worse, it may be bad. Here is what I need you to check.
You will need a live data scanner to do this. When the engine stalls and will not start, using the scanner, see if there is an RPM signal. If there is no signal, try a different sensor.
If you have no access to a scanner, when it won't start, you will need to check for spark to the plugs. Here is a link that explains how that is done:
Here is a link that explains common symptoms related to a failing crankshaft position sensor. See if it seems to mirror what you are experiencing.
Also, when it is running, does the check engine light stay on? If so, have you scanned for diagnostic trouble codes?
Oct 22, 2019 at 12:13 PM
