2002 Chevy Tahoe crankshaft position sensor error codes P03
130,000 MILES • V8 • 4WD • AUTOMATIC
TODD BENOIT
The engine has begun to stall as I'm driving, usually highway, and seems to happen as I'm decelerating. The RPM drops to 0, doors lock & unlock, electrical warning light indicator activates, lose power steering. An aftermarket programmer, Hypertech, used mainly to compensate for slightly larger tires (33"), that also required a 3" body lift, indicated the above error codes. The programmer allows me to reset the codes and the vehicle runs perfectly.
Should I change the sensor myself? If I do will I have to do a Crankshaft Variation Relearn? Should I have someone check the wiring and ECM with diagnostic tools?
What would you do?
Mar 11, 2009 at 6:18 PM
JAMES W.
  • 2,394 POSTS
First, I would double check the connections to the CPS. They have had connection problems in the past. If all is good, I'd change the sensor, clear the codes in the ECM and just drive it and see what happens. Hope this helps.
Mar 11, 2009 at 6:42 PM
