AC not blowing cold air?
2007 SUZUKI XL7
DONM47
I sent you a question yesterday about the AC not working rite. The problem I'm having, to recap, is the AC not blowing cold air. I've checked the fuses, belts, sensors and have checked to see if there's a leak in the system, there's none, up until a few days ago the system worked great. I did have problem, like the one that is happening now, a few months ago the AC quit blowing cold air and I checked everything also, then a few days later it started blow cold air again. This is the problem I'm have can you HELP?
Jun 29, 2009 at 4:42 PM
DOCFIXIT
  • 18,828 POSTS
Hi
First need to know the pressure readings. To determine if system is fully charged.
Is the A/C compressor working? IE. clutch engaged?
Read the guide below, it will help
Jun 30, 2009 at 7:09 AM
DONM47
What should the pressure at? Also I don't have a gauge system to take the readings with and I'm trying to avoid taken the car to a repair shop. Like I said earlier up until two days ago everything was working great.
Jun 30, 2009 at 5:15 PM
DOCFIXIT
  • 18,828 POSTS
Hi
Your system is computer controled with numerous components. With out gague readings and a scanner there is very little that can be done. And you have done those checks. Find an AC shop and have them run a diagnosis then post will advise.
Jul 1, 2009 at 4:25 AM
