1997 Suzuki Sidekick vibration
78,000 MILES • 4 CYL • 4WD • AUTOMATIC
GODFROIE
hi, my sidekick vibrate and the more i speed up the more it vibrate, over 60 it is the worst, i tried changing and balancing the tire, and changing the driveshaft but it is not better. the vibration comme from under the seat and there is a sound and i can t tell what it is, the car go streat does not pull either way so my alignement must be correct. where can i look next. thank you very much. jean-marc jacob
Oct 13, 2009 at 3:37 AM
RACEFAN966
  • 5,029 POSTS
Ok I would look at driveline u-joints (front and rear driveline), driveshaft carrier bearing (if equiped) and then I would look at front drive axles and wheel bearings. Let me know what you find.
Oct 14, 2009 at 3:16 AM
