1992 Suzuki Sidekick Converter fails to lock-up "3 spe
1992 SUZUKI SIDEKICK
RUSTYBORE
Transmission problem
1992 Suzuki Sidekick 4 cyl Automatic 84000 miles
At about 60,000 miles I becan having trouble with the lock-up converter or overdrive. I got where it would only lock-up when it was cold, now it never locks up. I would like to get this fixed for better fuel economy, I would also like to install a lock-out switch for when I pull a small trailer to the solid wast disposal.
Second question: Same vehicle. while looking for a loose wire that might cause the problem above, I found a wire hanging from the power steering pump, it appears to come from a sender of some type. I'm unable to find a place to connect this 10 inch wire. Would this have something to do with the transmission problem above?
I have owned this sense it was new, it has never been in a collision and everything is still 100% Suzuki except for air conditioning that was dealer installed.
Thank you,
Dale
Aug 4, 2010 at 11:53 AM
MMPRINCE4000
  • 8,548 POSTS
Most likely the lockup solenoid is bad, or possible wiring issue (connector to lockup solenoid).
Other possibiities are: the engine must be at operating temp, brake switch working and vehicle speed sensor.
In general the solenoid (failure) is more common.
You can wire a lockout, by tapping into ground side of solenoid switch (or power) and wiring to a switch on dash.
ECM commands lockup, although it may command lockup, does not mean it does, because solenoid is bad or wiring to it, or other items mentioned above.
Aug 6, 2010 at 2:37 AM
