1991 Suzuki Sidekick exhust
1991 SUZUKI SIDEKICK
GIVEMESUM6699
1991 Suzuki Sidekick 4 cyl Four Wheel Drive Automatic
i have white smoke comming out my exhust what does that mean??
Jul 22, 2009 at 10:38 AM
KICK-FIX
  • 29 POSTS
if it lingers and smells like burning oil then it is and you need new valve seals or the piston rings are worn.
or worse,major motor damage.
if the white smoke , is steam it will wisp away fast just like the steam on a tea pot lid does.
this is a bad head gasket.
steam from the tail pipe is normal at all cold startups.
it must go way after the motor reaches normal
operating temperature.
these answers are for common fails.
There are many things that can go wrong.
Sep 2, 2009 at 5:40 AM
