Oil sump removal
SUZUKI
EDM418
Hi Everyone, thanks for taking the time to view and/ or reply!
I drive a 1980 Suzuki SC100. My oil pressure warning light comes on intermittently, I want to remove the sump at the bottom of the engine to check the oil pump and the oil strainer.
My question is; can I safely remove the oil sump housing while the engine is in situ? (will anything fall out??)
the engine designation is; F10A, 997cc.
cheers, edm[img:405314f873]http://www.2carpros.com/forum/automotive_pictures/123582_introductie_05_2.jpg[/img:405314f873]
Nov 27, 2007 at 4:42 PM
  • 31,937 POSTS
Hi there,
The only thing that will fall out is the engine oil if you don't drain it first! Get the oil hot and let it drain over night so it wont be dripping on you with the sump off.
Mark (mhpautos)
Nov 27, 2007 at 4:46 PM
EDM418
Ok! thanks for your prompt response, I'll try that in the weekend and hopefully a good clean and a new filter will do the trick!
cheers, edm
Nov 27, 2007 at 4:58 PM
EDM418
Hi again, so, I have removed all of the bolts holding the sump to the engine block, but will it move? no... it will not! Am I missing something here? I had thought that prying with a screwdriver would have popped the seals but it is not going anywhere...
Any ideas?
Thankyou, edm.
Nov 30, 2007 at 4:37 PM
  • 31,937 POSTS
Hi there,
If all the bolts are removed and it is still stuck, it could be a chemically bonded sump, It will not have a conventional gasket, but it is sealed with a very strong sealant, You have to knock a small wedge in to start to break the seal, when it starts to give a little move along and knock in another wedge, there are special "splitting chisels" used i made my own as these sumps are becoming more frequent. see how you get on if in doubt re post.
Mark (mhpautos)
Nov 30, 2007 at 5:48 PM
EDM418
Right, thanks mate.
Night time now, so I'll hit it in the morning.
I have scraped a little of the gasket away, it's a kind of brick colored powder... hopefully it's not some kind of Super Sealant as I have to be back on the road on monday!
thanks again, edm.
Nov 30, 2007 at 5:57 PM
