1992 Suzuki Sidekick No Injector Pulse
SUZUKI
BROTHER BEAR
1992 suzuki sidekick 51961 miles 1.6L 8 valve engine. No injector pulse. Car quit while running and will not start. mechanic says not injector itself. fuses are good. What drives this injector and where is it located? What might other causes of failure be? Thanks
Jan 10, 2007 at 12:02 PM
2CARPRO JACK
  • 11,533 POSTS
Have the PCM scanned. The injector drivers are in the PCM, but the PCM gets signal from other things such as cam and crank position sensors, Mass Airflow Meters.. etc.If there is a problem the PCM might have stored a code that will help you start in the right direction
Jan 10, 2007 at 11:33 PM
MATHIASO
  • 1,209 POSTS
If no pulse signal is received, the problem is probably in the computer-control system
Jan 11, 2007 at 1:41 AM
Suggested Repair
Scan the PCM for stored codes. The injector drivers are inside the PCM, which relies on inputs such as the crank and cam position sensors and the mass airflow meter, so a missing injector pulse points to the computer-control system or those related inputs rather than the injector itself.
Conversation Summary
A 1992 Suzuki Sidekick with a 1.6L 8-valve engine quit while running and will not restart because there is no injector pulse. Fuses are good and a mechanic says the injector itself is not the cause. Experts advise scanning the PCM, noting that the injector drivers are in the PCM and that it depends on signals from sensors such as the crank and cam position sensors and mass airflow meter. If no pulse is received, the fault is likely in the computer-control system.
