Suzuki XL7 AC Squeal and Hot Air
SUZUKI
DEC0578
I have a suzuki XL7 and when I drive it and turn on the air conditioner I hear a loud squeaking sound, and then when I accelerate I hear a rattling sound? My husband called and said that the ac is only blowing hot air now. What do I need to do? How much will this cost? Thank you so much
Aug 14, 2006 at 8:47 AM
MIKEYBDMAN
  • 623 POSTS
[quote:66783807ae="dec0578"]I have a suzuki XL7 and when I drive it and turn on the air conditioner I hear a loud squeaking sound, and then when I accelerate I hear a rattling sound? My husband called and said that the ac is only blowing hot air now. What do I need to do? How much will this cost? Thank you so much[/quote:66783807ae]
First off, stop trying to use the a/c until it is fixed. The squealing you hear is the belt slipping. It will eventually break and leave you stranded. As long as you dont attempt to run the A/C the belt will be fine.
As for the problem, it sounds like your compressor has seized up.
Aug 14, 2006 at 9:06 AM
Suggested Repair
Stop using the A/C until it is repaired so the slipping belt does not break and leave the vehicle stranded. The symptoms point to a seized A/C compressor; have the compressor and drive belt inspected and repaired.
Conversation Summary
The owner of a Suzuki XL7 reports a loud squeak when the air conditioner is turned on, a rattle during acceleration, and A/C that now blows only hot air. The expert advises not using the A/C until it is fixed because the squeal is a slipping belt that can eventually break. The expert says the compressor appears to have seized.
