Clutch pedal on the floor?
2007 SUZUKI FORENZA
47,200 MILES • 4 CYL • 2WD • MANUAL
ELAHXCKID41
the clutch does not have any resistance when i press on it with my foot and when the car is on, i cant put the car into gear. i purchased dot 3 and 80w 90 gear oil for the car, but i cant find the filler hole.
#1: Where's the fill hole?
#2: Should I
a) Fill the transmission with ONE of the oils?
b) Tow it to a Mechanic
Nov 21, 2008 at 1:19 PM
  • 31,937 POSTS
Hi there,
The clutch master ids bolted to the fire wall and it has a small reservoir attached check the fluid level, if it ids low there will be a leak in the master or slave cyl, if you add fluid and bleed the system you will have enough clutch to drive to get it repaired.
mark (mhpautos)
Nov 21, 2008 at 2:10 PM
