2005 Ford F-350 Suspension Type
299,000 MILES • 6.0L • V8 • TURBO • 2WD • AUTOMATIC
BUCKF350SD6.0L
How do I know if I have a mono beam or twin beam suspension? I have the truck listed above crew cab SD with 6.0L diesel.
Oct 23, 2017 at 12:57 PM
STEVE W.
  • 15,411 POSTS
You have the Twin-I beam system as it is a two wheel drive. Monobeam is the solid front axle in the 4X4's. Use 2CarPros anytime, we are here to help. Please tell a friend.
Oct 23, 2017 at 7:15 PM
DAVIS0509
  • 8 POSTS
i have a 1989 Chevrolet k3500 4x4 7.4L Silverado. do i have a Monobeam front suspension? i believe it's the SS version of that year.
Oct 29, 2020 at 11:47 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
No, your front suspension is not Monobeam but called torsion bar style suspension. I've attached a picture below. Hope this helps and thanks for using 2CarPros.
Oct 29, 2020 at 12:35 PM
DAVIS0509
  • 8 POSTS
that be the one. thanks Danny!!!
Oct 29, 2020 at 3:01 PM
DANNY L
  • 5,648 POSTS
You're welcome!
Glad to help. I've owned two K1500's myself an 1989 and a 1997- See pictures below. Hope you will use our site again in the future. Thanks again for using 2CarPros.
Danny-
Oct 29, 2020 at 3:15 PM
Suggested Repair
Identify the front suspension by drivetrain rather than replacing parts. The 2005 Ford F-350 two-wheel drive uses Twin-I-Beam; monobeam is the solid front axle used on the 4x4 models. The 1989 Chevrolet K3500 4x4 uses torsion-bar front suspension, not monobeam.
Conversation Summary
The owner of a 2005 Ford F-350 Super Duty crew cab with a 6.0L diesel asked how to tell monobeam from twin-beam suspension. The expert said a two-wheel-drive truck has Twin-I-Beam, while monobeam is the solid front axle used on 4x4 models. A second owner then asked about a 1989 Chevrolet K3500 4x4 and was told it uses torsion-bar front suspension, not monobeam. The owner confirmed that matched the truck.
